Sunroof and interior lights not working
As per title the sunroof and none of the interior lights are working. The led for the alarm isnt flashing either. Had a quick look at the rear fuses but cant see anything easily.....will have a look in daylight and track down the front fuse box unless anyone else has any suggestions?
Sound like a fuse as you've already guessed. Open glove box look up and you'll see a couple of clips that twist and then you can open the flap.
Re: Sunroof and interior lights not working
Ok so went through most of the fuses.....there really are a lot! No change and nothing blown.
Booked into BWM next week......came home pulled the centre console down...unplugged everything......plugged it all back in and hay presto it all works again.
I assume that ive just managed to reset something.
Saves a trip to the stealers though.
